Siebel Enterprise Integration Manager Administration Guide > Merging Data > Checking Merge ResultsWhen a merge process ends, you should carefully check the results to verify that data was successfully merged. During each process, EIM writes comprehensive status and diagnostic information to several destinations. During a merge process, EIM writes the following values to two special columns in the EIM tables:
To view the results of a merge
If error flags, SQL trace flags, or trace flags were activated for the EIM process, you can also use the trace file to view the results of the EIM process. For more information on viewing the trace file, see Viewing the EIM Log File. |
Siebel Enterprise Integration Manager Administration Guide |
