Siebel Enterprise Integration Manager Administration Guide > EIM Performance Tuning > Troubleshooting EIM Performance >
Example: Using the USE INDEX HINTS and USE ESSENTIAL INDEX HINTS Parameters
The following example illustrates the results achieved for an SQL statement with index hints and without index hints. This example was performed on the MS SQL Server platform.
SQL User Name |
CPU |
Reads |
Writes |
Duration |
Connection ID |
SPID |
SADMIN
549625 |
38844200 |
141321 |
626235 |
516980 |
9 |
UPDATE dbo.S_ASSET5_FN_IF
SET T_APPLDCVRG__RID =
(SELECT MIN(BT.ROW_ID)
FROM dbo.S_APPLD_CVRG BT (INDEX = S_APPLD_CVRG_U2)
WHERE (BT.COVERAGE_CD = IT.CVRG_COVERAGE_CD AND
BT.TYPE = IT.CVRG_TYPE AND
BT.ASSET_ID = IT.T_APPLDCVRG_ASSETI AND
(BT.ASSET_CON_ID = IT.T_APPLDCVRG_ASSETC OR
(BT.ASSET_CON_ID IS NULL AND IT.T_APPLDCVRG_ASSETC IS NULL)) AND
(BT.INSITEM_ID = IT.T_APPLDCVRG_INSITE OR
(BT.INSITEM_ID IS NULL AND IT.T_APPLDCVRG_INSITE IS NULL))))
FROM dbo.S_ASSET5_FN_IF IT
WHERE (CVRG_COVERAGE_CD IS NOT NULL AND
CVRG_TYPE IS NOT NULL AND
T_APPLDCVRG_ASSETI IS NOT NULL AND
IF_ROW_BATCH_NUM = 10710001 AND
IF_ROW_STAT_NUM = 0 AND
T_APPLDCVRG__STA = 0)
SET STATISTICS PROFILE ON
GO
SET STATISTICS IO ON
GO
select
With hints: Table 'S_APPLD_CVRG'. Scan count 1, logical reads 394774, physical reads 0, read-ahead reads 280810.
Table 'S_ASSET5_FN_IF'. Scan count 1, logical reads 366, physical reads 0, read-ahead reads 0.
Without hints: Table 'S_APPLD_CVRG'. Scan count 1268, logical reads 10203, physical reads 697, read-ahead reads 0.
