Siebel Enterprise Integration Manager Administration Guide > EIM Performance Tuning > Database Guidelines for Optimizing EIM >
IBM DB2 UDB
  • Use the IBM DB2 load replace option when loading EIM tables and, if possible, turn off table logging.
  • Use separate tablespaces for EIM tables and the base tables.
  • Use large page sizes for EIM and the larger base tables. Previous experience has determined that a page size of 16 KB or 32 KB provides good performance. The larger page sizes allow more data to be fitted on a single page and also reduces the number of levels in the index B-tree structures.
  • Similarly, use large extent sizes for both EIM and the large base tables.
  • Consider using DMS containers for all Siebel tablespaces. Using raw devices or volumes will further help to improve performance.
  • Make sure that the tablespace containers are equitably distributed across the logical and physical disks and across the input/output (I/O) controllers of the database server.
  • Use separate bufferpools for EIM tables and the target base tables. Since initial EIM loads are quite large and there are usually no online users, it is recommended to allocate a significant amount of memory to the EIM and the base table bufferpools.
  • Reorganize the tables if data on disk is fragmented. Use the reorgchk utility with current statistics to find the fragmented tables or indexes.
  • Periodically make sure that table and index statistics are collected. Do not use RUNSTATS with the DETAILED option.
  • Use IBM DB2 snapshot monitors to make sure performance is optimal and to detect and resolve any performance bottlenecks.
  • Log retain can be turned OFF during the initial load. However, you should turn it back on before moving into a production environment.
  • For the EIM tables and the base tables involved, alter the tables to set them to VOLATILE. This makes sure that indexes are preferred over table scans.
  • Consider the following settings for DB2 registry values:
    Registry Value
    Setting
    DB2_CORRELATED_PREDICATES =
    YES
    DB2_HASH_JOIN =
    NO
    DB2_RR_TO_RS =
    YES
    DB2_PARALLEL_IO =
    DB2_STRIPPED_CONTAINERS =
    When using RAID devices for tablespace containers
  • Consider the following settings for the DB2 database manager configuration parameters:
    Registry Value
    Setting
    INTRA_PARALLEL =
    NO (may be used during large index creation)
    MAX_QUERYDEGREE =
    1 (may be increased during large index creation)
    SHEAPTHRES =
    100,000 (depends upon available memory, SORTHEAP setting, and other factors)
  • Consider the following settings for the database parameters:
    Registry Value
    Setting
    CATALOGCACHE_SZ =
    6400
    DFT_QUERYOPT =
    3
    LOCKLIST =
    5000
    LOCKTIMEOUT =
    120 (between 30 and 120)
    LOGBUFSZ =
    512
    LOGFILESZ =
    8000 or higher
    LOGPRIMARY =
    20 or higher
    LOGRETAIN =
    NO (only during initial EIM loads)
    MAXLOCKS =
    30
    MINCOMMIT =
    1
    NUM_IOCLEANERS =
    Number of CPUs in the database server
    NUM_IOSERVERS =
    Number of disks containing DB2 containers
    SORTHEAP =
    10240 (This setting is only for initial EIM loads. During production, set it to between 64 and 256.)
    STAT_HEAP_SZ =
    8000
