Siebel Enterprise Integration Manager Administration Guide > EIM Performance Tuning > Monitoring the Siebel ServerWhen monitoring the Siebel server, the assumption is that you have allocated sufficient processor and memory resources for running the EIM task on the Siebel application servers and Siebel database servers. If you are using Windows 2000 as the operating system for the Siebel server, the Windows Performance Monitor can be used to verify the amount of processor and memory being used by the hardware. If you are using Sun Solaris or IBM AIX as operating systems for the Siebel Server, you can use |
Siebel Enterprise Integration Manager Administration Guide |
