Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Enterprise Integration Manager Administration Guide > Running EIM > Viewing the EIM Log File > Setting Event Logging from the Graphical User Interface (GUI)You can set event logging for the EIM component using the Administration - Server Configuration views in the Siebel client. NOTE: You can also set event logging using the SrvrMgr command line. See Setting Event Logging from the Command-Line Interface. To set event logging for the EIM component from the GUI
It is not necessary to restart the Siebel server to apply the event type log level changes. The changed settings are active in the next EIM task executed. For more information on event logging administration, see System Monitoring and Diagnostics Guide for Siebel eBusiness Applications. |
Siebel Enterprise Integration Manager Administration Guide |
