Siebel Enterprise Integration Manager Administration Guide > EIM: Examples of Common Usage > EIM Import Process Examples > Visibility of Fields: Example of Importing ContactsThis example provides a sample .IFB file for importing contacts. The contact visibility depends on S_CONTACT_BU to resolve the organization and S_POSTN_CON for the position. INCLUDE = "Import Contact Informationen" INCLUDE = "Import POSTN_CON Informationen" [Import Contact Informationen] ONLY BASE TABLES = S_PARTY, S_CONTACT, S_CONTACT_BU DEFAULT COLUMN = CON_ACTIVE_FLG, "Y" DEFAULT COLUMN = CON_DISACLEANSEFLG, "N" DEFAULT COLUMN = CON_DISPIMGAUTHFLG, "N" DEFAULT COLUMN = CON_EMAILSRUPD_FLG, "N" DEFAULT COLUMN = CON_EMP_FLG, "N" DEFAULT COLUMN = CON_PRIV_FLG, "N" DEFAULT COLUMN = CON_INVSTGTR_FLG, "N" DEFAULT COLUMN = CON_PO_PAY_FLG, "N" DEFAULT COLUMN = CON_PROSPECT_FLG, "N" DEFAULT COLUMN = CON_PTSHPCONTACTFL, "N" DEFAULT COLUMN = CON_PTSHPKEYCONFLG, "N" DEFAULT COLUMN = CON_SENDSURVEY_FLG, "N" DEFAULT COLUMN = CON_SPEAKER_FLG, "N" DEFAULT COLUMN = CON_SUPPRESSEMAILF, "N" DEFAULT COLUMN = CON_SUPPRESSFAXFLG, "N" |
| Siebel Enterprise Integration Manager Administration Guide |
