| Siebel Field Service Guide > Agreements > Process of Creating Agreements > Creating Documents for Agreements, Quotes, and Orders
 Field Service can automatically generate documents required to implement a service agreement; for example, subcontractor agreements and work orders. For information about how to create document templates using Siebel Proposals see Siebel Correspondence, Proposals, and Presentations Guide.  To generate an agreement document
Navigate to the Agreements screen > List view.
Drill down on the Name field for a selected agreement record.
Click the Documents view tab.
Create a new record and complete the fields as appropriate.
Some fields and buttons are described in the following table.
    | Auto Document | Command and button. Creates a new record from the default document template. |
    | Generate Draft | Command. Creates a draft document and opens it in Microsoft Word or Lotus WordPro.  |
    | Local | Indicates this document is stored locally. This field is for information only; there is no associated code. | Click Generate Draft.
The system launches Microsoft Word or Lotus WordPro and displays a draft agreement. Alternatively, you can click Auto Document to create a standard document from the default template. To generate an order document
Navigate to the Service Order or Sales Order screen > List view.
Drill down on the Order # field for a selected order record.
Alternatively, you can click Auto Document to create a standard document from the default template. To generate a quote document
Navigate to the Quotes screen > List view.
Drill down on the Name field for a selected quote record.
Alternatively, you can click Auto Document to create a standard document from the default template. |
