Siebel Field Service Guide > Agreements > Agreements Screen > Notes ViewThe Notes view allows you to add notes to an agreement. You can add a private note (visible only for the logon ID under which it was created) on the Private tab or a public note (visible to all users) on the Public tab. |
| Siebel Field Service Guide |
