| Siebel Field Service Guide > Cycle Counting and Replenishment >  Running the Cycle Counting Engine
 Follow these procedures to carry out cycle counts of inventory. To run the Cycle Counting Engine interactively
Navigate to the Inventory screen > Cycle Counts view.
In the Inventory Locations list, select an inventory location record for cycle counting.
Do one of the following:
 To review pending cycle counts and parts lists for cycle counting
In the Inventory Locations list, select an inventory location record.
The Cycle Counts subview shows records describing each instance of a cycle count. Pending cycle counts have a status of Open or Assigned.Select a cycle count record.
Drill down on the Status field hyperlink.
The Part List tab shows all items included in the selected cycle count. To record the results of a cycle count
Navigate to the Cycle Counts screen > Cycle count List view.
In the My Pending Cycle Counts list, drill down on the Status field hyperlink.
In the Part List list, In the Count field of each product record, enter the quantity counted.
If a counted item is serialized:
Select the product record.
Enter a value in the Count field.
Click the Counted Serial Numbers subview tab.
In the Counted Serial Numbers list, create a record for each serialized asset that is an instance of that product.
 To complete a cycle count
Navigate to the Cycle Counts screen > Cycle Count List view.
In the Part List list, click Count Complete.
This populates the records in the Variance view and the Counted Serial Numbers subview. To review a cycle count
Navigate to the Cycle Counts screen > Cycle Count list view
Click the Variance view tab.
Review the results (Original, Count, and Variance) of the product count and counted serial numbers, if applicable.
To adjust the inventory, click Adjust.
