Siebel Field Service Guide > Fulfillment > Administration - Data Screen >
Order Actions View
The Order Actions view defines the actions that may be associated with an order type. An administrator chooses action types from a drop-down list. The choices available in this menu are set in the Administration - Data screen > List of Values view. CAUTION: Never delete order types or order action types, as their ROW_IDs provide values for tables elsewhere in Orders. To change or replace an order type or an order action type, modify the List of Values and then update (do not delete and re-enter) the Type entry.
