Implementing Siebel Business Applications on DB2 UDB for z/OS > Customizing a Development Environment > Custom Extensions to the Siebel SchemaThere are several different possible scenarios for Siebel Schema extensions:
CAUTION: If a LONGVARCHAR column is defined for a table, attempting to add an extension column to the table causes an error. This is because a LONGVARCHAR column uses all the space in a table space that is not used by the non-LONGVARCHAR columns, leaving no space available for an extension column. In this case, use an extension table instead. For further information, see How Siebel Systems Implements LONG Columns on DB2 for z/OS. The process of creating a small extension column is the same on z/OS as on other platforms and is documented in the Using Siebel Tools guide. To create a large extension column or an extension table, you must specify a 16-KB or
NOTE: Creating tables with Identity type columns or extension columns of Identity type is not supported. For information on estimating storage needs, see Preparing for Implementation on the DB2 Host. |
| Implementing Siebel Business Applications on DB2 UDB for z/OS |
