Implementing Siebel Business Applications on DB2 UDB for z/OS > Customizing a Development Environment > Process of Applying Schema Extensions to the Target DatabaseAfter testing your schema customizations in the local environment, you can migrate them to the target user-acceptance or production database. You must perform the following tasks: |
| Implementing Siebel Business Applications on DB2 UDB for z/OS |
