Implementing Siebel Business Applications on DB2 UDB for z/OS > Installing the Siebel Database Server Files at Midtier >
Process of Installing the Database Server
To install the Siebel Database Server, perform the following tasks:
- Fill out your copy of Appendix A, "Deployment Planning Worksheet" with the parameter values that you need to perform the installation. Distribute copies to the entire installation team. See Deployment Planning Worksheet.
- Ensure all the prerequisite installation tasks are completed. See Preinstallation Tasks for the Siebel Database Server.
- Install the Siebel Database Server software. See Installing the Database Server Software Under Windows and Installing the Database Server Software Under UNIX.
- Review the software installation. See Reviewing the Software Installation for DB2 for z/OS.
- Install and configure the Siebel Schema. See Installing the Siebel Schema on the DB2 Host.
- Import the Siebel repository and complete post-installation tasks. See Siebel Repository Import and Postinstallation Tasks.
