Implementing Siebel Business Applications on DB2 UDB for z/OS > Installing the Siebel Schema on the DB2 Host > Preparing for a Custom Installation >
Working with CLOBs Using the Database Storage Configurator
Your Siebel application is delivered with the objects needed to create character large objects (CLOBs). You can use these objects to create CLOBs at the table level only, to avoid excessive processing overhead. To activate a CLOB
- Launch the Database Storage Configurator as described in Modifying Storage Control Files Using the Database Storage Configurator and select the Table tab.
- Review the contents of the CLOB column.
- To activate a specific CLOB, type Yes in the appropriate row in the CLOB column, and then save the value by stepping off the cell.
NOTE: The Auxiliary Tablespace tab displays a table name that is used as a pointer to a real auxiliary table space. The parameters displayed under this tab are the only parameters you can change for the auxiliary object.
- Make any other changes needed to the template you are using. Then follow the steps under Modifying Storage Control Files Using the Database Storage Configurator to verify and save your changes.
