Implementing Siebel Business Applications on DB2 UDB for z/OS > Siebel Repository Import and Postinstallation Tasks > Postinstallation Tasks for the Siebel Repository >
Loading Statistics
Execute the script, loadstat.sql, to load the statistics required for the operation of the Siebel application into the DB2 catalog. To edit and run the loadstat.sql script
- Locate the script, loadstat.sql, within the
DBSRVR_ROOT\db2390 directory (Windows) or the $DBSRVR_ROOT/db2390 directory (UNIX).
- Follow the instructions documented inside loadstat.sql to edit the file, making sure to change the variable
SIEBELTABLECREATOR to the CREATOR for the Siebel Schema as defined in the DB2 catalog.
- Execute the script using any method you prefer.
