Implementing Siebel Business Applications on DB2 UDB for z/OS > Maintenance Considerations for z/OS > Dynamic SQL in the Siebel Application > How to Enable ODBC TracingYou can enable ODBC tracing by following the instructions in FAQ 1343, available on Siebel SupportWeb. ODBC tracing produces results similar to the CLI trace, but focuses on the ODBC API calls. You cannot see the data being passed in the SQLExecute calls with the ODBC trace but you can see it in the DB2 CLI traces. |
| Implementing Siebel Business Applications on DB2 UDB for z/OS |
