Implementing Siebel Business Applications on DB2 UDB for z/OS > Migrating Data Using Siebel EIM > About Setting Up EIM for DB2 >
EIM and Table Partitioning
The mechanism by which EIM generates the ROW_ID can result in an uneven distribution of data if you use EIM with one of the default partitioning schemes to import data into a base table. See EIM Table Partitioning and Data Distribution for recommendations about how to avoid uneven data distribution in a partitioned table containing data imported by EIM.
