Implementing Siebel Business Applications on DB2 UDB for z/OS > Configuring the Database Layout >
About the Siebel Database Server Installation
The Siebel Database Server installation process uses two types of Siebel control files:
- DDL control file
The DDL control file contains the logical definitions for all Siebel tables and indexes for the current version of the Siebel Business Application. The DDL control file (ddl.ctl or schema.ddl) is read-only to protect the integrity of the Siebel data model.
- Storage control file
The storage control file contains the physical database layout. The storage control file is specific to DB2 for z/OS.
Carefully review the storage control file (or the resulting schema.sql file that is based on the storage control file) and adjust the database layout to satisfy your database requirements. Your can modify any option available for each database object, for example, by fine-tuning FREEPAGE and PCTFREE for a particular table space or a group of table spaces.
NOTE: It is especially important that you review SEGSIZE, PRIQTY, and SECQTY for the table spaces that are to contain the major tables for your implementation. Siebel Systems has appropriately sized the table spaces used for Siebel repository tables, but because sizing requirements for base Siebel tables vary from deployment to deployment, it is your responsibility to set storage parameters capable of accommodating your installation.
Together, the DDL control file and the storage control file provide Siebel Business Applications with all the information necessary to create DDL for the Siebel Schema in an output file (by default named schema.sql). You can choose either of two methods to execute the SQL files from a designated Siebel Server:
