Implementing Siebel Business Applications on DB2 UDB for z/OS > Understanding Siebel Partitioning > Example of Partitioning: the S_ADDR_ORG Table >
Example of a Tsparts Definition
In the example for the Tablespace object 3197, illustrated above, Partitions=10; therefore, ten Tspart objects must be defined, as shown in the following example for objects 3198 through 3208). [Object 3198] Type = Tspart Name = H0401000 PartNum = 1 ... [Object 3208] Type = Tspart Name = H0401000 PartNum = 10
Example of the DDL for the Partitioned Table Space
The storage control file definitions for the partitioned table space in the previous example result in the following output DDL statements: CREATE,TABLESPACE H0401000 IN SIDB0401 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 LOCKPART YES DEFINE NO NUMPARTS 10 (PART 1 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO, PART 2 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO , PART 3 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO , PART 4 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO , PART 5 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO , PART 6 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO , PART 7 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO , PART 8 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO , PART 9 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO , PART 10 USING STOGROUP SYSDEFLT PRIQTY 48 SECQTY 1440 FREEPAGE 4 PCTFREE 30 COMPRESS NO ) BUFFERPOOL BP1 LOCKSIZE PAGE LOCKMAX 0 COMPRESS NO /
