Implementing Siebel Business Applications on DB2 UDB for z/OS > Preparing to Deploy Siebel on DB2 for z/OSThere are a number of issues you need to consider when preparing your implementation of Siebel Business Applications using IBM DB2 UDB for z/OS (hereafter referred to as DB2 for z/OS). These issues are covered in depth throughout this guide. This guide also describes how to install the Siebel Database Server and the Siebel Schema. For information on installing the core Siebel products, see the Siebel Installation Guide for the operating system you are using. This chapter contains the following topic: Process of Preparing for a Siebel Application Deployment on DB2 for z/OS |
| Implementing Siebel Business Applications on DB2 UDB for z/OS |
