Siebel Life Sciences Guide > Siebel Advanced Contracts > About Configuring the Add Benefits ButtonYou can configure the Add Benefits button so that the available benefit templates are constrained by the parent entitlement record. This button is located in Agreements > Entitlements > Benefits. If you configure the Add Benefits button, only templates associated with the parent entitlement record will be displayed in the Benefit Template Popup Applet. If you do not configure this button, the Benefit Template Popup Applet will display all available benefit templates instead of constraining the list to those associated with the parent entitlement template. |
Siebel Life Sciences Guide | Copyright © 2008, Oracle. All rights reserved. | |
