Siebel Life Sciences Guide > Siebel Advanced Contracts >
Creating Term Templates
This section assumes you have administrator privileges. In this example, the administrator is setting up the term templates for the entire company. To create a term template
- Navigate to the Contracts Administration screen.
- Select Term Templates in the Contracts Administration screen.
- Create a new record and complete the necessary fields.
Some fields are described in the following table.
Term # |
The number of the term. |
Term Name |
A representative description for the term; for example, Term Length. |
Type |
The legal type of the term: standard, non-standard, or special. |
Description |
The actual term as it is used in the agreement. |
