Siebel Life Sciences Guide > Managing CAPAs >
Managing CAPAs (End User)
Use the views on the Corrective Actions screen to store, maintain, and share many types of information about a CAPA. Typically several employees are assigned ownership of a CAPA record and are assigned activities related to the CAPA. All owners update the CAPA record during the course of the CAPA's life cycle. To add information to CAPA records
- Navigate to the Corrective Actions screen > Corrective Action List view.
- Drill down on a CAPA record.
- Update the record by editing status, comment, and date fields.
- Create activity plans for the CAPA:
- Click the Activity Plan view tab.
- In the Activity Plans list, create a new record and complete the necessary fields.
Some fields are described in the following table.
Planned Start |
Make sure that this date is correct before you choose a template. The due dates for the template-generated activities are based on this start date and on the lead time set in the template. |
Template |
Only templates whose type is Corrective Action can be selected in this field. |
- Edit the activities in the Activities list or create more activities.
- Create private and public notes for the CAPA record using the Notes view.
- Associate files to the CAPA record using the Attachments view.
For general information about activities, notes, and attachments, see Siebel Fundamentals.
