Siebel Life Sciences Guide > Using Personalized Content Delivery > Working with Messaging Plans >
Associating Help to Messaging Plans
You can create help text for your messaging plan. To associate help text for a messaging plan
- Navigate to the Administration - Messaging Plans screen > Messaging Plans view.
- In the Messaging Plan list, select a record, and drill down on the Name field.
- Click the Help File tab, click New, and add the help text for the messaging plan.
Some fields are described in the following table.
Name |
Enter the name of the help file. |
Description |
Enter a description of the help file. |
Sub Type |
Use the drop-down list to select a sub type for the help file. |
Literature Type |
Use the drop-down list to select a literature type for the help file. |
- Select a record, and click Delete if you want to remove the help text for a specific messaging plan.
