Siebel Life Sciences Guide > Using Personalized Content Delivery >
Defining System Preferences for PCD
Your system administrator must define the following system preferences before you can begin to use PCD.
- Server Uncompression Location
Specifies the Siebel Server file path location from where uncompressed message files are cached.
- Decompressed Files Path
Specifies the relative path to cache uncompressed message files when using Siebel Mobile Web Client.
- CheckForNeedToSync
For remote users, only messages with the user property, NeedToSync, set to Y are decompressed. Otherwise, all messages are decompressed.
- Skin
Specifies the theme as custom graphical appearances for PCD.
For more information about setting system preferences, see Setting System Preferences for PCD. Table 58 lists the system preference values that you need to set before you start using PCD.
