Siebel Life Sciences Guide > Using Personalized Content Delivery > Managing Content for PCD >
Associating Attributes with PCD Content
You can associate attributes such as name, product, segment, and so on, with the PCD content to enable users to filter content based on the specified values. To associate attributes with the PCD content
- Navigate to the Document Administration > Literature view.
- In the Literature list, select a record.
- Click the Applies To tab, and indicate which product, indications, decision issues, and therapeutic class that the message applies to.
Some fields are described in the following table.
Product |
Select the product that you want to apply to the message. |
Indication |
Use the drop-down list to select the indication for which the message was designed. |
Issues |
Use the drop-down list to select the issue that the message was designed to address. |
Therapeutic Class |
Use the drop-down list to select the therapeutic class for which the message was designed. |
