Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Loyalty Promotion Examples >
Example of Creating a Complex Frequency Promotion
A complex frequency promotion gives members a varying bonus that depends on the number of times they buy a product during a given period. For example, during a specific period:
- Fly DEN - CHI 3 times, receive 1,000 bonus
- Fly DEN - CHI 4 or 5 times, receive 3,000 bonus
- Fly DEN - CHI 6 or more times, receive 5,000 bonus
Unlike a simple frequency promotion, a complex frequency promotion does not give members a bonus as soon as the complete the required number of actions. Instead it waits until the end of the promotion period to give a bonus, because the bonus that is given varies in a step function based on the total number of applicable purchases. This example assumes that you have already created the loyalty program and the product needed for this promotion. This example shows one possible use of complex frequency promotions. Your use of these promotions may differ, depending on your business model. Creating the Promotion Record for the Complex Frequency Promotion
The promotion record is a container for all the other information about the promotion. When you create the promotion record, you do not have to select Always Apply, because this promotion will be processed at a pre-set date and the decision to give bonus points will not be triggered by a transaction. Thus, it will always apply automatically. The Final Action Date field determines when this promotion is processed. You should set it for several days after the end of the promotion, to give time for all applicable transactions to be processed. To view this field, you must click the More button on the Promotion form. The engine will process the promotion on the day after the date specified in this field. To create the promotion record
- Navigate to the Loyalty Promotions Administration screen.
- Add a new Promotion record and complete the necessary fields. Some fields are shown in the following table.
Name |
Complex Frequency DEN - CHI Promotion |
Always Apply |
No |
Apply To |
Accrual-Product |
Promotion Start |
1/21/2006 |
Promotion End |
4/1/2006 |
Product Inclusion |
Include Products |
Final Action |
4/10/2006 |
- Click the Promotion #.
The Promotion form appears.
- In the Promotion form, click the Show more button.
- In the Final Action Date field, enter 4/6/2006.
Specifying the Product for the Promotion
Because this promotion applies only to airline flights, you selected Include Products in the Product Inclusion when you created the promotion. Now you must specify the product it applies to. To specify the product for this promotion
- Click the Products view tab.
- Add a new Product record and complete the necessary fields. Some fields are shown in the following table.
NOTE: If this product does not exist in your database, you will need to create it and make it available to Siebel Loyalty. For more information, see Defining Loyalty Features of Products, Price Lists, and Catalogs.
Creating the Attribute for the Promotion
You must create an attribute that will be used by this promotion's rule. This attribute will be used to count the number of times that the member takes the DEN - CHI flight. To create the attribute for this promotion
- Click the Promotion Specific Attributes view tab.
- Add a new Promotion Specific Attribute record and complete the necessary fields. Some fields are shown in the following table.
Name |
DEN - CHI Complex Freq Promo Attribute |
Field |
Number 1 |
Default |
0 |
Data Type |
Number |
- When you have finished creating the attribute, select the Active check box.
Creating a Rule That Updates the Attribute
You must create a rule that increments the value of the attribute every time the member takes a DEN - CHI flight. To create a rule that updates the attribute
- Click the Rules view tab.
- In the Rules list, add a new record and complete the necessary fields. Some fields are shown in the following table.
Sequence |
1 |
Name |
Update the DEN - CHI Complex Freq Promo Attribute |
Apply To |
Transactions |
- Click the rule's Name field hyperlink.
- In the Criteria list, add a new Criteria record and complete the necessary fields in the record and in the Compare to Values detail form, as shown in the following table.
Sequence |
1 |
Name |
Partner = Indigo Airlines |
Type of Comparison |
Compare to Values |
Object |
Transaction |
Attribute |
Partner |
Condition |
Equals |
Value |
Indigo Airlines |
NOTE: If desired, you could add additional criteria, such as ticket class.
- Click the Actions view tab.
- Add a new Action record and complete the necessary fields in the Action list and Detail form, shown in the following table.
This action updates the promotion specific criteria each time the member takes this flight.
Sequence |
1 |
Name |
Update Promo-Specific DEN-CHI Attribute |
Type |
Update Attribute |
Update this attribute |
Object |
Promotion |
Attribute |
Action |
Add |
And/Or this value |
Value |
1 |
Creating Rules That Give the Members Bonuses
You must also create rules that give the members bonuses. One rule is created for each different bonus amount a member could receive. In this example, there are three potential bonuses so there are three rules:
- A rule to give 1,000 points to members who fly from DEN to CHI 3 times during the promotion period.
- A rule to give 3,000 points to members who fly from DEN to CHI 4 or 5 times during the promotion period.
- A rule to give 5,000 points to members who fly from DEN to CHI 6 or more times during the promotion period.
To create a rule that give the members a 1000 point bonus for 3 flights
- In the thread bar, click Promotion:Complex Frequency DEN - CHI Promotion.
- Add a new Rule record and complete the necessary fields. Some fields are shown in the following table.
Sequence |
2 |
Name |
If DEN-CHI Flights = 3, Give 1,000 Points |
Apply To |
Attributes |
- Click the rule name.
- In the Criteria list, add a new Criteria record and complete the necessary fields in the record and its detail form, as shown in the following table.
Sequence |
1 |
Name |
# of DEN-CHI Flights = 3 |
Compare to Values |
Object |
Promotion |
Attribute |
Condition |
Equals |
Value |
3 |
Sequence |
1 |
Name |
Give 1,000 Regular NQ Points |
Type |
Assign Points |
Point Type |
Regular |
Value |
1000 |
To create a rule that gives the members a 3000 point bonus for 4 or 5 flights
Sequence |
3 |
Name |
If DEN-CHI Flights = 4 or 5, Give 3,000 Points |
Apply To |
Attributes |
Sequence |
1 |
Name |
# of DEN-CHI Flights = 4 or 5 |
Compare to Values |
Object |
Promotion |
Attribute |
Condition |
Equals |
Value |
4 |
Value |
5 |
NOTE: Add two rows to the Value list. Enter 4 in one and 5 in the other.
Sequence |
1 |
Name |
Give 3,000 Regular NQ Points |
Type |
Assign Points |
Point Type |
Regular |
Value |
3000 |
To create a rule that gives the members a 5000 point bonus for 6 or more flights
Sequence |
4 |
Name |
If DEN-CHI Flights >= 6, Give 5,000 Points. |
Apply To |
Attributes |
Sequence |
1 |
Name |
# of DEN-CHI Flights >= 6 |
Compare to Values |
Object |
Promotion |
Attribute |
Condition |
Is Greater Than Or Equal To |
Value |
6 |
Sequence |
1 |
Name |
Give 5,000 Regular NQ Points |
Type |
Assign Points |
Point Type |
Regular |
Value |
5000 |
Activating the Promotion
Now that all the rules have been set up, you are ready to activate the promotion. After the promotion is activated, it will keep track of the number of times that members fly between the start date and the end date. Then, on the day after the date in the Final Action Date field, it will give points to members based on the total number of DEN-CHI flights they took during this period. To activate the promotion
- In the Promotion form, click Activate.
The promotion will be active during the period between the start date and the end date.
