Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Process of Creating Loyalty Promotions > Specifying Products Included in a Loyalty PromotionYou can create loyalty promotions that apply to all products or that apply only to the products you specify. When you create the Loyalty Promotion record, you must choose one of these values in the Product Inclusion field:
If you select All Products, skip this procedure. If you select one of the other two options, use this procedure to list the products that are included or excluded. This task is a step in Process of Creating Loyalty Promotions. To specify products included in or excluded from a promotion
| Siebel Loyalty Administration Guide |
