Siebel Marketing Installation and Administration Guide > Creating Source Code and Vendor Profiles > Setting Up Vendor Profiles >
Defining Distribution Profiles for Vendors
Use the Communication Administration screen's Drivers and Profiles view to define communications profiles for email, fax, and FTP distribution of lists to vendors. Output file layouts and vendor profiles must be defined for all types of lists. If you are using email or FTP, you must also define Email Address, Distribution Method, and Distribution Profile in the Vendor profile. For more information about using delivery profiles, read Siebel Marketing User Guide. Siebel Marketing provides default drivers in its library that can be modified for use when sending files to a vendor. An administrator can create distribution profiles for each of these driver types that override the default parameters for that driver. For more information about communications drivers and profiles, read Siebel Communications Server Administration Guide.
