Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > SOAP Calls for Marketing >
purgeCache Method
The purgeCache method purges the entire cache, purges entries for a segment from the cache, or purges entries for a segment tree from the cache.). If the node specified is a non-leaf node then the cache for all its children leaf nodes will be purged. API Definition
Method
<binding name="JobManagementService" type="i0:JobManagementServiceSoap"> <soap:binding transport="http://schemas.xmlsoap.org/soap/http" style="document" /> <operation name="getCounts"> <soap:operation soapAction="#purgeCache" style="document" /> <input> <soap:body use="literal" /> </input> <output> <soap:body use="literal" /> </output> </operation> </binding>
Method Input
<xsd:element name="purgeCache"> <xsd:complexType> <xsd:sequence> <xsd:element name="segmentPath" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="treePath" type="sawsoap: treeNodePath" minOccurs="0" maxOccurs="1" /> <xsd:element name="ignoreCacheRef" type="xsd:boolean" default="false" minOccurs="0" maxOccurs="1" /> <xsd:element name="sessionID" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType> </xsd:element>
<xsd:complexType name="treeNodePath"> <xsd:sequence> <xsd:element name="treePath" type="xsd:string" minOccurs="1" maxOccurs="1" /> <xsd:element name="treeNodePriority" type="xsd:string" minOccurs="0" maxOccurs="1" /> <xsd:element name="treeNode" type="xsd:string" minOccurs="0" maxOccurs="1" /> </xsd:sequence> </xsd:complexType>
Method Output
<xsd:element name="purgeCacheResult"> <xsd:complexType> <xsd:sequence> <xsd:element name="jobInfo" type="sawsoap:JobInfo" /> </xsd:sequence> </xsd:complexType> </xsd:element>
Valid Usage Scenarios
All cache content is purged from cache. <purgeCache> </purgeCache>
Purges entries for the segment from cache. <purgeCache> <segmentPath>[path to the segment]</segmentPath> </purgeCache>
Purges entries for the segment tree from the cache. <purgeCache> <treePath>[path to the segment tree]</treePath> </purgeCache>
Usage Options
None.
