Siebel Marketing Installation and Administration Guide > Installing and Administering Segmentation and List Generation > About Mapping Segmentation MetadataSegmentation identifies a group of targets for applying a marketing treatment. Typically, targets are individuals, businesses, bank accounts, or households but they can be any dimensional entity in the database such as Opportunities or Assets. Use the marketing segmentation user interface to specify criteria that groups targets based on behavior patterns. The Segmentation Metadata specifies this criteria and is composed of the following entities:
For instructions about how to create segmentation metadata, read Siebel Analytics Server Administration Guide. When you have created the segmentation metadata, you need to test the integrated environment. If you customize your data warehouse with a new column and you want Siebel Marketing to access the new column, make sure that the column is exposed in all three layers of the Analytics repository. For more information, read "Setting Up Marketing Segmentation Metadata", in Siebel Analytics Server Administration Guide. |
| Siebel Marketing Installation and Administration Guide | Copyright © 2006, Oracle. All rights reserved. | |
