Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events > BusComp_NewRecord EventThe NewRecord event is called after a new row has been created in the business component and that row has been made active. The event may be used to set up default values for Fields. SyntaxReturnsUsageBusComp_NewRecord is called when a new record is created unless the new record was created:
In these cases, BusComp_CopyRecord is called instead of BusComp_NewRecord. Used WithExampleFor an example, read Pick Method. |
Siebel Object Interfaces Reference |
