Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events > BusComp_PreNewRecord EventThe PreNewRecord event is called before a new row is created in the business component. The event may be used to perform preinsert validation. SyntaxReturnsContinueOperation or CancelOperation UsageCancelOperation stops the execution of the underlying Siebel code associated with the event. However, if there is code in the same script following CancelOperation, that code runs regardless of the CancelOperation. Used With |
Siebel Object Interfaces Reference |
