Siebel Object Interfaces Reference > Interfaces Reference > Business Object Methods > GetLastErrCode MethodThe GetLastErrCode method returns the last error code. SyntaxReturnsThe last error code as a short integer; 0 indicates no error. UsageAfter execution of a method, the GetLastErrCode can be invoked to check if any error was returned from the previous operation. The GetLastErrText method can be invoked to retrieve the text of the error message. Used WithCOM Data Control, Mobile Web Client Automation Server See Also |
| Siebel Object Interfaces Reference |
