Siebel Object Interfaces Reference > Interfaces Reference > Business Service Methods > GetFirstProperty MethodThis method retrieves the name of the first property of a business service. SyntaxReturnsA string containing the name of the first property of the business service UsageThis method retrieves the name of the first property, in order of definition, of a business service. Use GetFirstProperty and GetNextProperty to retrieve the name of a property. You can then use the retrieved name as an argument to GetProperty to retrieve the property value, or with SetProperty to assign property values. Used WithBrowser Script, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExamplesThis function returns the number of Property Sets that belong to the Business Service given in parameter. The following example is in Siebel eScript: function countPropSets(busService) while(propSetName != null && propSetName != "") The following example is in Java: public int countPropSets(SiebelService busService) catch(SiebelException sExcept) See Also |
| Siebel Object Interfaces Reference |
