Siebel Object Interfaces Reference > Interfaces Reference > Control Methods >
SetProperty Method
The SetProperty method sets visual properties of a control. Syntax
controlVar.SetProperty(propName, propValue)
propName |
The name of the property to be set, as described in the following table |
propValue |
The value to assign to the property, as described in the following table |
Returns
Not applicable Usage
SetProperty can be used with the following controls: CheckBox, ComboBox, TextBox, and TextArea. If more than one property is to be set, each must be set in a separate statement. The following table lists the properties that can be set for a control, and the values that can be assigned to them.
BgColor |
string |
Determines Background Color for a control: for example, red is "ff0000", green is "00ff00", and blue is "0000ff" |
Enabled |
TRUE or FALSE
Is the button active? (Unless explicitly modified by using SetProperty, default is TRUE.) |
FontColor |
string |
Determines FontColor for a control: for example, green is "00ff00" |
FontType |
string |
Determines FontType for a control: for example, "Times Roman" |
FontSize |
string |
Determines FontSize for a control: for example, "12 pt" |
FontStyle |
string |
Determines FontStyle for a control: for example, "Bold" |
Height |
string |
Determines Height for a control, in pixels: for example, "5" |
Shown |
TRUE or FALSE
Is the control shown? (Unless explicitly modified by using SetProperty, default is as defined in the repository.) |
ReadOnly |
TRUE or FALSE
Determines whether the control is read-only. Defaults to repository definition unless explicitly modified by using SetProperty. |
Visible |
TRUE or FALSE
Determines whether the control is visible. Defaults to repository definition unless explicitly modified by using SetProperty. |
Width |
string |
Determines Width for a control, in pixels: for example, "80" |
Used With
Browser Script Example
The following code shows the use of SetProperty. objCheckBox.SetProperty("FontColor", "00ff00"); objCheckBox.SetProperty("FontStyle", "italic"); objCheckBox.SetProperty("FontType", "Verdana"); objCheckBox.SetProperty("FontSize", "25pt"); objCheckBox.SetProperty("BgColor", "00f000"); objCheckBox.SetProperty("Width", "100"); objCheckBox.SetProperty("Height", "100");
