Siebel Order Management Guide > Product Data Service and Import/Export API Reference > Product Data Services API Methods >
ExecuteSearch Method
Executes the search on products based on the input search option, such as product class, class attributes, attribute constraints, pricing criteria, and so on. External Syntax
ErrCode ExecuteSearch (const CCFPropertySet& inputArgs, CCFPropertySet& outputArgs);
Arguments
const CCFPropertySet& inputArgs |
In |
Option, OptionId, Context, ContextMode, SearchSpec, ResultSize, BatchNumOfId, SiebelMessage |
CCFPropertySet& outputArgs |
Out |
Hierarchy :SiebelMessage |
Details of Input Arguments
Option |
String |
For example: Application Software |
Product class name or All (flat product class search) NOTE: This property must be provided if the OptionId property is not specified.
OptionId |
String |
For example: 1-3CE27 |
Indicates the Row_id of the product class record. NOTE: This property must be provided if the Option property is not specified.
Hierarchy |
See the examples that follow this table. |
SearchSpec |
If the Option property is not set to All, or the OptionId is specified, this property set contains the constraints on the class attributes. If the Option property is set to All, this property set contains the criteria on product fields or an individual child property set (where SearchSpec can be specified for the explicit SearchSpec expression). |
ContextMode |
String |
SiebelContext, ExternalContex, NoEligibility |
SiebelContext: Using existing Quote/Order Information in Siebel Database. In this case, the API will construct the Context based on the provided row_id ExternalContext: External Call will provide the context information, API will pass them directly to the Pricing and Eligibility Process. NoEligibility: Does not check eligibility. |
ResultSize |
Number |
For example: 30 |
The number of products that are retrieved from the query result. |
BatchNumOfId |
Number |
For example: 50 |
The number of row IDs that are concatenated at once and that respond to the SQL QUERY statement. This number is set to 50 by default, depending on the database configuration. |
Context |
Hierarchy |
None. |
Integration Object |
SiebelMessage |
PDS Product Interface |
None. |
Example of Input Arguments
CCFPropertySet@0013BA34 p#3 c#2 type="" vt=0 value=""
p["ContextMode"] = "SiebelContext";
p["ResultSize"] = "50";
p["Option"] = "All";
c[0] CCFPropertySet@0C1EA490 p#0 c#2 type="ContextWrapper" vt=0 value=""
c[0] CCFPropertySet@0C1BEDE0 p#4 c#0 type="Context" vt=3 value=""
p["BusObjName"] = "Quote";
p["ContextRowId"] = "2-47J4V";
p["SignalMode"] = "Quote";
p["BusCompName"] = "Quote";
c[1] CCFPropertySet@0C1B3F50 p#0 c#2 type="SearchSpecWrapper" vt=0 value=""
c[0] CCFPropertySet@0C1454D0 p#0 c#3 type="SearchSpec" vt=3 value=""
c[0] CCFPropertySet@0B87A2C8 p#0 c#0 type="SearchSpec" vt=3 value="[Name] = 'UANProduct1' or [Name] = 'UANProduct3'"
c[1] CCFPropertySet@0AFDBAC0 p#0 c#0 type="ListPrice" vt=3 value="[List Price]>45"
Example of ExternalContext Input
CCFPropertySet@0013B958 p#11 c#0 type="Header" vt=3 value="2-47J4V"
p["Account Id"] = "";
p["City"] = "";
p["Currency Code"] = "USD";
p["State"] = "";
p["Eligibility Display Mode"] = "1";
p["Discount Percent"] = "";
p["Account Contracted Products Only Flag"] = "";
p["Exchange Date"] = "03/04/2005";
p["Account Type"] = "";
p["Postal Code"] = "";
p["Price List Id"] = "2-47J4M";
Example of Output Arguments
CCFPropertySet@0013C1F0 p#0 c#1 type="" vt=0 value=""
c[0] CCFPropertySet@0C203838 p#4 c#1 type="SiebelMessage" vt=0 value=""
p["MessageId"] = "2-3ZPA";
p["IntObjectName"] = "PDS Product Interface";
p["MessageType"] = "Integration Object";
p["IntObjectFormat"] = "Siebel Hierarchical";
c[0] CCFPropertySet@0BADEAE0 p#0 c#2 type="ListOfProduct" vt=0 value=""
c[0] CCFPropertySet@0C1EDBC0 p#7 c#1 type="ListOfInternalProduct" vt=0 value=""
c[0] CCFPropertySet@0C1FA3C0 p#21 c#0 type="Internal Product" vt=0 value=""
p["PrePick"] = "Y";
p["Id"] = "2-47J3S";
p["Name2"] = "UANProduct1";
p["PriceType"] = "One-Time";
p["PrePick"] = "Y";
p["Id"] = "2-47J4E";
p["Name2"] = "UANProduct3";
Error Conditions
The 'Data Sync Service: ExecuteSearch' user property is not defined in business service 'PDS Product Data Service |
The specified user property can not be found on the business service, which should have value PDS Product by default. |
Cannot get property set 1%. |
The required property set input 1% is not provided. |
Unable to locate record with row id as '%1' in '%2 |
The specified row_id 1% in BC 2% could not be found. |
Unable to create the Business Service PDS Product |
Can not initiate the business service. |
