Siebel Order Management Guide > Product Data Service and Import/Export API Reference > Product Data Services API Methods >
DeleteOrder Method
Deletes the order that matches the input. Syntax
ErrCode DeleteOrder(const CCFPropertySet& inputArgs,CCFPropertySet& outputArgs);
Arguments
const CCFPropertySet& inputArgs |
In |
Hierarchy :SiebelMessage(Integration object PDS Order) |
CCFPropertySet& outputArgs |
Out |
Hierarchy :SiebelMessage |
Example of Input Arguments
CCFPropertySet@0012D384 p#0 c#1 type="" vt=0 value=""
c[0] CCFPropertySet@0A6E4FE8 p#4 c#1 type="SiebelMessage" vt=0 value=""
p["MessageId"] = "42-1D9U";
p["MessageType"] = "Integration Object";
p["IntObjectName"] = "PDS Order";
p["IntObjectFormat"] = "Siebel Hierarchical";
c[0] CCFPropertySet@0ACADCC0 p#0 c#1 type="ListOfPDS Order" vt=0 value=""
c[0] CCFPropertySet@0A903FE8 p#17 c#1 type="Header" vt=0 value=""
p["Account Location"] = "";
p["Id"] = "42-50SHP";
p["Revision"] = "1";
p["Account Id"] = "";
p["Status"] = "Pending";
p["Conflict Id"] = "0";
p["Order Type"] = "Service Order";
p["Account"] = "";
p["Contact Id"] = "";
p["Currency Code"] = "USD";
p["Discount"] = "";
p["Updated"] = "02/11/2005 13:54:39";
p["Integration Id"] = "";
p["Opty Id"] = "";
p["Order Number"] = "PDS Order Item Test";
p["Created"] = "02/11/2005 13:54:39";
p["Price List Id"] = "";
c[0] CCFPropertySet@0A900550 p#0 c#1 type="ListOfLine Item" vt=0 value=""
c[0] CCFPropertySet@0AB61530 p#62 c#1 type="Line Item" vt=0 value=""
p["NRC CxTotal"] = "0";
p["Parent Id"] = "";
p["Cfg State Code"] = "New Item";
p["Volume Discount Item Id"] = "";
p["Id"] = "42-50SHW";
p["Cfg Type"] = "";
p["Eligibility Reason"] = "";
p["Exclude Pricing Flag"] = "N";
p["Extended Quantity Requested"] = "1";
p["Asset Integration Id"] = "42-50SHW";
p["Root Id"] = "42-50SHW";
p["Need Refresh"] = "Y";
p["Prod Prom Name"] = "";
p["Volume Discount Item"] = "";
p["Line Number"] = "1";
p["Product Id"] = "42-50S1M";
p["Smart Part Number"] = "";
p["Discount"] = "";
p["Prod Item Id"] = "";
p["Discount Percent"] = "";
p["Original List Price"] = "";
p["Updated"] = "02/11/2005 13:56:09";
p["Current Price"] = "";
p["Eligibility Status"] = "";
p["Port Item Id"] = "";
p["Prod Prom Id"] = "";
p["Has Generics Flag"] = "";
p["Inclusive Eligibility Flag"] = "N";
p["Integration Id"] = "42-50SHW";
p["Post Pick CD"] = "";
p["Prod Prom Instance Id"] = "";
p["Rollup Amount"] = "0";
p["Forcastable Flag"] = "";
p["Prod Prom Rule Id"] = "";
p["Discount Source"] = "Manual";
p["List Price"] = "";
p["Pricing Comments"] = "";
p["Volume Upsell Item"] = "";
p["Effective To"] = "";
p["Unit Price"] = "";
p["Price Type"] = "One-Time";
p["Product Line Id"] = "No Match Row Id";
p["Rollup Item Price"] = "0";
p["Volume Discount Id"] = "";
p["Created"] = "02/11/2005 13:54:50";
p["Due Date"] = "02/12/2005 00:00:00";
p["Effective From"] = "";
p["Prod Prom Source Id"] = "";
p["Discount Amount"] = "";
p["Exchange Date"] = ""; p["Item Price List Id"] = "";
p["Pre Pick CD"] = "";
p["Volume Upsell Message"] = "";
p["Configuration Model Id"] = "42-50S1M";
p["Name"] = "PDS Product";
p["Quantity"] = "1";
p["Action Code"] = "Add";
p["MRC CxTotal"] = "0";
p["Volume Upsell Item Id"] = "";
c[0] CCFPropertySet@0A92EE38 p#0 c#0 type="ListOfXA" vt=0 value=""
Example of Output Arguments
CCFPropertySet@0012DA78 p#0 c#1 type="" vt=0 value=""
c[0] CCFPropertySet@0AB9F028 p#4 c#1 type="SiebelMessage" vt=0 value=""
c[0] CCFPropertySet@0AC32B10 p#0 c#1 type="ListOfPDS Order" vt=0 value=""
c[0] CCFPropertySet@0A63EB20 p#0 c#0 type="Header" vt=0 value=""
Error Conditions
None. This method calls the help method described in DeleteQuote Method.
