Siebel Order Management Guide > Using Asset-Based Ordering > Ungrouping Quote or Order Line ItemsIf the product's Auto Explode flag is set, when a quote is turned into an order, line items with a quantity of more than one are ungrouped to become separate instances, each with a quantity of one. Ungrouping only applies to asset-based ordering and to assets for which the Auto Explode flag is set. If the end user enters quantities greater than one, the quote-to-order process automatically ungroups them. Ungrouping is needed to give each asset separate a Service ID, so it can be tracked and serviced in the future. It also gives each asset a separate integration ID, which is used by the back-end provisioning system for fulfillment. The ungroup feature allows you to configure once for multiple items and then splitting them into individual items that can have their own variant configurations, telephone numbers, or Billing/ Service accounts, as described in Ungrouping or Exploding Quote Line Items. NOTE: This procedure shows how to ungroup quote line items. Use a similar procedure to ungroup order line items, but drill down on the Orders list rather than the Quotes list. NOTE: This procedure shows how to ungroup line items in a quote for an asset owned by an account. You can also ungroup line items in a quote for an asset owned by a contact using a similar procedure, by navigating to the Contacts screen, then the Contact Summary view.
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
