Siebel Order Management Guide > Using Asset-Based Ordering > Basic Concepts of Asset-Based Ordering > About Products and AssetsThe following concepts related to products and assets are important in asset-based ordering. Service ProductsA service product is a product that is not a physical product, although it is often associated with one. For example, a service that is delivered over time, such as telephone or electrical service, is considered a service product. A service product may have physical components. For instance, a residential electric service would include a meter. A product becomes a service product if it is marked as one in the product record. Integration IDAn integration ID is a unique identifier that is assigned to each trackable asset when it becomes a line item in a quote or an order. The integration ID does not appear on the screen. NOTE: It is important that this field not be used for other purposes, as this may affect the functions of the Order Line Items, Quote Line Items, and Assets. |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
