Siebel Order Management Guide > Creating a Quote or Sales Order > Process of Enabling the Automatic Configuration of Customizable ProductsWhen you enable the automatic configuration of customizable products that are based on a promotion definition, you enable the automatic configuration of the following relationships: You also populate the default settings of the promotion on the line item. You can add a promotion line item to a quote or order in any of the following ways:
NOTE: In previous versions of Siebel Order Management, when you added a promotion line item to a quote, the existing line items that got associated with the new promotion line item were not automatically configured with the default settings of the new promotion. The default settings of the promotion were populated only when they enter the Siebel Configurator session. In addition, the default settings of the promotion were not populated on the existing relationships of the customizable product when they enter the Siebel Configurator session. To enable the automatic configuration of customizable products that are based on a promotion definition, perform the following tasks:
For more information about the automatic configuration of customizable products, see the following: |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
