Siebel Order Management Guide > Creating a Quote or Sales Order > Process of Creating a Quote >
Starting a Quote
You can start a new quote from a number of screens:
- If you start the quote from the account, contact, or opportunity screen, your Siebel Business Application automatically copies the account, contact, or opportunity information into the quote. If a price list is associated with the account or opportunity, it is also entered.
- If you start the quote using the Quotes screen, you must enter all this information manually.
For information about how to start a quote using an existing asset, see Using Asset-Based Ordering. This task is a step in Process of Creating a Quote. To start a quote
- Perform one of the following actions, depending on which screen you want to use to start the quote:
- To start a quote from the Quotes screen, navigate to the Quotes screen.
- To start a quote from an opportunity, navigate to the Opportunities screen, Opportunities List view, drill down on the name of the opportunity for which you want to generate a quote, and then click the Quotes view tab.
- To start a quote for an account, navigate to the Accounts screen, Accounts List view, drill down on the name of the account for which you want to generate a quote, and then click the Quotes view tab.
- To start a quote for a contact, use the site map to navigate to the Contacts screen, Contacts List, then the Quotes view; in the Contacts list, select the name of the contact for which you want to generate a quote.
- In the Quotes list, add a new record. The information in the following table is entered automatically. Not all of this information is visible in the Quotes views of the Opportunity, Account, or Contact screen, but if you create quotes from these views, the information will be visible when you display the quotes in the Quotes screen.
Sales Rep |
Displays the name of the user who created the quote. |
Quote # |
Displays a unique system-generated number assigned to the quote when it is created. |
Revision |
Displays the number indicating which revision of the quote this is. When the quote is created, this value is 1. |
Created |
Displays the date the quote was created. |
Active |
A checkbox indicating whether the quote is active. When you create a quote, it is automatically selected, since the quote is active. NOTE: The quote must be designated as active in order to attach files to it or otherwise update it.
Status |
Displays the initial status of the quote, In Progress. The status can be changed later, as the quote process continues. For example, if you convert the quote to an order, the status changes to Order Placed. Other statuses for the quote are defined by your company. Some of the statuses companies often use include Approved, Rejected, Expired, Placed, and Active. |
Effective As Of |
Defaults to the created date. You can change this, if appropriate. |
Effective Through |
Defaults to the effective date plus 30 days. You can change this if the quote will be available for a different length of time. |
Currency |
Displays the default currency for the quote. |
- Enter the following information in the new record:
Name |
Enter a name for the quote. If you do not enter a name, the quote number is assigned as the name. |
Price List |
Enter a price list to be used for the quote, if one is not assigned automatically through association with the account. Available price lists are restricted by the currency associated with this quote. |
Discount |
(Optional.) Enter a Override Policy Discount discount for this quote. This discount will be used instead of any pricing rules associated with a price list. For more information, see Applying a Manual Discount. NOTE: If you created the quote from the Quotes views of the Opportunity, Account, or Contact screen, you must drill down on the quote name to the quote in the Quotes screen to view this field of the Quote record.
Opportunity |
(Optional.) Select an opportunity associated with the quote. The account associated with opportunity is automatically inserted. NOTE: If you created the quote from the Quotes views of the Opportunity, Account, or Contact screen, you must drill down on the quote name to the quote in the Quotes screen to view this field of the Quote record.
Account |
Select the account with which the quote should be associated, if one has not been entered automatically. NOTE: If you created the quote from the Quotes views of the Opportunity, Account, or Contact screen, you must drill down on the quote name to the quote in the Quotes screen to view this field of the Quote record.
Last Name and First Name |
Select the contact for this quote, if one has not been entered automatically. NOTE: If you created the quote from the Quotes views of the Opportunity, Account, or Contact screen, you must drill down on the quote name to the quote in the Quotes screen to view this field of the Quote record.
Due |
(Optional.) Enter a due date for the quote. NOTE: If you created the quote from the Quotes views of the Opportunity, Account, or Contact screen, you must drill down on the quote name to the quote in the Quotes screen to view this field of the Quote record.
