Siebel Order Management Guide > Creating a Quote or Sales Order > Process of Creating a Sales Order That Is Not Based on a QuoteThis section describes how to create a new order that is not based on a quote. NOTE: If you have already created a quote, create the order by converting that quote to an order, rather than by using the procedures in this section. The order automatically includes all the details from the quote, so you do not have to reenter them. For more information, see Converting a Quote to an Order. Creating an order that is based on a quote allows you to verify the quote to check for any errors. If you are creating a complicated order that might have errors, you should do it by creating quote, verifying the quote, and then converting the quote to an order. For more information, see Process of Creating a Quote. To create an order that is not based on a quote, perform the following tasks:
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
