Siebel Order Management Guide > Setting Up Product Recommendations >
Product Recommendation Technical Reference
In order to customize recommendations to suit your business model, you can modify the controlling workflow, the Recommendation Procedure, and the business service used to implement product recommendations. For more information about workflows, see Siebel Business Process Framework: Workflow Guide. The Recommendation Procedure is a PSP procedure. For more information about PSP procedures, see Siebel Order Management Infrastructure Guide. Product recommendations are based on:
