Siebel Order Management Guide > Integrating Order Management with Third-Party Product Availability Applications > Process of Setting Up Third-Party Product Availability Applications > Customizing UI Terms for Availability to PromiseYou can change the following terms in the user interface to more precisely reflect the type of data expected by, and returned by, your particular product availability fulfillment engine.
These two fields are designed to work together, reflecting parallel information. This task is a step in Process of Setting Up Third-Party Product Availability Applications. |
| Siebel Order Management Guide | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
