Siebel Order Management Guide > Integrating Order Management with Third-Party Credit-Check Applications > Process of Setting Up Purchase Order Credit Checking Applications >
Configuring Web Services for Purchase Order Credit Checking Applications
Web services are used to direct the inbound and outbound messages to and from:
  • The third-party credit checking application
  • A demonstration script that can be used to test your integration setup
  • A middleware or integration server that will integrate with your fulfillment engine and accounts receivable system
You must make sure that the Web services are correctly configured.
This task is a step in Process of Setting Up Purchase Order Credit Checking Applications.
To configure the Web services
  1. Navigate to the Administration - Web Services screen, then the Outbound Web Services view.
  2. Select the row with External Credit Check in the Name field.
  3. Verify that the fields in the Outbound Web Services list match those in the following table.
    Namespace
    Name
    Status
    http://siebel.com/asi/
    Active
  4. In the Service Ports list, click New, and enter the following values in the fields of the new record.
    Field
    Comments
    Name
    Enter a name for the port.
    Port Type
    Enter External Credit Check.
    Transport
    Select from the drop-down list.
    If you want to set up testing, for example when you are customizing applets or extending the ASI, select Local Business Service.
    Address
    When you select a transport, the field will be populated with a template address. Edit the address based on whether you are sending the data to middleware, the Credit Check application, and so on.
    If you want to set up testing, enter Credit Check ASI Test.
    Binding
    If a SOAP header is expected by the receiving application, select SOAP_RPC.
    If you are using Credit Check ASI Test, select Property Set.
Siebel Order Management Guide Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices.
