Siebel Order Management Guide Addendum for Industry Applications > Setting Up Network Ordering >
Configuring Cascade Deletion for a Disconnected Network
Use the following procedure to configure cascade deletion for a disconnected network. For more information about cascade deletion, see Configuring Siebel Business Applications. To configure cascade deletion for a disconnected network
- Log in to Siebel Tools with administrator privileges.
- Query for the VORD CPVE Node business component and lock the project.
- Modify the Search Specification property based on the value of the ValidateFieldName user property.
For example, the following search specification assumes the value of the ValidateFieldName user property is Service Id:
(Connection.[Node] = Node.[Node] OR Connection.[To Node] = Node.[Node]) AND ((Connection.[Compound Product Number] = Node.[Compound Product Number] OR Connection.[Compound Product Number] = Node. [Serial Number]) AND Connection.[Root Asset Id] = Connection.[Id] AND Connection.[Status] = LookupValue('IMPL_PHASE','Active'))
- Compile the project.
