Siebel Order Management Guide Addendum for Industry Applications > Partner Asset-Based Ordering > Order Management with Standard Partner Commerce > Saving a Shopping Cart as a Quote or Quote Template (Standard Partner Commerce)When the user saves the shopping cart, the system first verifies the user is logged in. If not, the user is required to log in. If the user is not a registered user, the application makes the user register. When the user saves the shopping cart as a quote, the quote is added to My Quotes. The user can convert the quote to an order at a later time. When the user converts a quote to an order from My Quotes, the quote is removed from My Quotes. When the user saves a quote as a template, the quote is added to My Templates. The user can use the template to create orders at a later time. Templates are not removed from My Templates when they are used to create quotes. To save a shopping cart as a quote or quote template
| Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
