Siebel Order Management Infrastructure Guide > Data Validation Manager > Process of Invoking the Data Validation Manager Business Service >
Viewing a Validation History
You can view a history of validation events in the Validation History view. All events display in chronological order. To view the validation history
- Navigate to the Administration - Data Validation screen, then Validation History view.
The Validation History view appears, displaying validation events. Some fields are described in the table that follows.
BusComp Name |
The business component that was validated. |
Date |
The date the validation event happened. |
Last Step # |
Sequence number of the rule evaluated to be false or the last rule in the rule set. |
Return Code |
The rule's Return Code field value. |
Return Message |
The rule's Message field value. |
Started By |
The login name of the user who executed this rule. |
Status |
Specifies the status of the validation result:
- Errored Out. Indicates Stop on Error is True. The current rule is evaluated to be false and further rule evaluation is halted.
- Error Proceed. Indicates Stop on Error is False; the current rule is evaluated to be false and the application proceeds to evaluate the next rule.
- Completed. Indicates the application has reached the last rule of the rule set and the rule is evaluated to be True.
For more information on defining rule sets and configuring the Return Code and Return Message fields, see Defining Validation Rules.
