Siebel Order Management Infrastructure Guide > Data Validation Manager > Process of Administering Data Validation Rules > Defining Rule Set ArgumentsYou can write a validation expression of a rule which contains user-defined arguments using a syntax such as [Some Buscomp Field Name] = [&Argument Name]. These arguments must be first defined in the Arguments list. Values of these arguments can be set using the Default Value field. They can also be set at run time by supplying an input argument to the Data Validation Manager business service. The input argument name must be the same as the argument name defined in the Arguments list. Business service input arguments will overwrite whatever default values you have specified in the Arguments list. The default values only take effect when input arguments are not provided. You can only define arguments for validation rule sets that have a status of In Progress. This task is part of Process of Administering Data Validation Rules.
| Siebel Order Management Infrastructure Guide | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
